Engraved - Question
I haven't tested it myself, however I imagine it'll work just fine. :) If not, you can ask for support in the customer forum and I'll be happy to help! :)
Ehren, is it possible to switch from Chameleon Dark to Engraved? I bought the Chameleon Dark and I'm having second thoughts and wish I would have gotten Engraved. Can you help me out with this or will I have to pay the full amount for the Engraved theme?
thanks!
thanks!
After downloading a skin, it is not possible to exchange, because Ehren considers that the skin is on your computer. If the exchange would be possible, pay skin wouldn't make more sense.
thanks!
Hi island55,
Unfortunately as mentioned above, skin exchanges or refunds are only offered if the theme has not been downloaded. However if you are also interested in purchasing Engraved, you'll receive an automatic $5.00 discount when it's added to your cart (plus free upgrades to 4.x for both themes if you are an active customer when 4.x is released). :)
Another quick question that involved Engraved, now that I purchased it :)
I really like the ability to be able to have a different icon for every forum, can you help me with that? The Chameleon Dark theme came with that option but Engraved does not :(
All themes come with that feature ;) There's a pinned topic in the tutorial forum for customizing forum icons.
Posted (edited)
Ehren, with the Engraved theme I noticed the header links have icons while selected. Is there a way to enable those icons to show even while not selected?
Edit: I think I answered my own question, all I did was remove the "li.active" from this line: "#primary_nav li.active .menu_icon{" in the ipb_styles.css - Did I do this correct?
Edited by island55
Correct. For any future support questions, go ahead and post in the Customer category since you now have access. :)
