Chameleon, Forge Channel...
Hey guys,
i´m looking for a new theme for my website.
I really like the Chameleon Theme, but is it possible to change the color of the overall look? The dark one comes with kinda black/grey tables, but i need them to be blue...
Is this possible or do i have to stick with the colors? Are there any forums out there using this theme with another background/color setting?
If it´s not possible, what theme is "forge channel" using? http://forgechannel.com/ is it a custom one?
This would be a walkaround to have a picture background and color-tables because it looks easier to make...
Hi Fabian,
It's possible to change the colour of the tables, however it would require a fair amount of work. If you change the background image to a blue one (or even just a solid blue hex colour), the content area will "inherit it" and become a light (or dark) shade of blue.
Forge Channel is using a custom theme. :)
Hey!
Thanks four you reply :)
Just in case it´s not a big deal for you, maybe you can post a little forum-index screenshot how it will look like just with the color #144869 as background (without a background-picture) using the light theme.
Two mock-ups are attached - one of Chameleon Dark, the other of Chameleon Light.
The opacity of the content box backgrounds can be reduced which would make them closer to the shade of blue used on the background.
