Footer Question re: Gridlock
Hi,
We like your gridlock layout and think it will work well for a brand new site we are going to build.
However it does not appear to have a footer like your uptop design has.
Is it possible to purchase the gridlock with a footer similar to the uptop one?
And we assume the gridlock is 3.4.6 compatible?
Many thanks,
Correct, Gridlock doesn't come with it's own footer but I can give you the code for it if you need to add it to your theme.
Gridlock is compatible with 3.4.6, yes. :)
Hope that helps!
Hope that helps!
Hi,
Great news, we have just purchased it so can you pm or email us that footer code and let me know where it needs placing.
Many thanks
