NickAndrew Posted November 7, 2013 Posted November 7, 2013 Hi all, Here to get a few answers before I make a purchase into the IPB community. I have a few designer friends that could hook me up with a custom logo for a a new forum. My question is - how easy/difficult it is to add your own logo to any ipb forum? Assuming it's made at the appropriate dimensions of whatever the logo space allows, I'm looking to buy a pre-made style I like enough and then add a custom logo Any possible pitfalls/problems or is it easy enough? Thanks for any feedback and answers. Nick
Solution Ehren Posted November 7, 2013 Solution Posted November 7, 2013 Hi Nick, Adding your own logo is very simple. Most of these skins come with a text logo by default which can be disabled easily (by changing one line of code). You then simply need to upload your logo image to the correct folder. There is a tutorial in the customer area with more detailed steps. As long as your logo is the right dimension, you won't have any issues!
NickAndrew Posted November 8, 2013 Author Posted November 8, 2013 Awesome that's the answer I was hoping for. Appreciate it I'll find that tutorial! 1
