These questions are relating to the Animate skin...
1.) Is is possible to add a background image to the forum, instead of just the black? Or if purchased would you be willing to show how this could be done.
2.) I am assuming the animated image in the top is changeable, is the banner text over lay or a image to?
3.) Would you do some customization work for the IP Content add-on home page.. really just how the news is displayed i want it to look similar to a different site.
4.) Would you make said background image?
5.) Does this skin support icons for forums on the home forum page?
I am assuming 3 and 4 might require extra payment? Hopefully not to much for 1 image, and some template changes though. Thanks for your future reply!
1. Yep - it's just styled by the background of the body tag
2. The animated image is simple to change and the logo is text (although it can be easily swapped to an image if needed)
3. I am not currently offering IP.C services
4. A custom background image is not included, no.
5. Yep, that feature exists for all of the premade skins :)
Hopefully that helps!
