HyperActive Posted July 26, 2013 Posted July 26, 2013 Is there a way to change the animated space image in the header? If so, where can I add my own animated image?
Solution Ehren Posted July 26, 2013 Solution Posted July 26, 2013 Hello, It's very simple to change the banner image, however you are not listed as a customer. You must first purchase the skin if you wish to use it on your forum. If not, it must be removed. Thank you.
HyperActive Posted July 28, 2013 Author Posted July 28, 2013 I do not currently own the skin, I was wondering if I could change the banner image before ordering the skin so I can use it
Ehren Posted July 28, 2013 Posted July 28, 2013 Hello, Yep - the image can be replaced very easily using the same process as any other image
