markcms Posted July 23, 2013 Posted July 23, 2013 hi i have a ipb forum 1.3.4 but i can't change icons i have tried with dp33 icon changer but when i upload one icon it say system error can't move file who i can add icon on forum? thank's in advance and sorry for my english
Ehren Posted July 23, 2013 Posted July 23, 2013 Hello, I would suggest contacting the author of that modification.
markcms Posted July 23, 2013 Author Posted July 23, 2013 Hello, I would suggest contacting the author of that modification. Hello, I would suggest contacting the author of that modification. is there any method? i use gravity green skin
Ehren Posted July 23, 2013 Posted July 23, 2013 You are not listed as a customer which suggests you have not purchased the skin. If this is true, the skin must be removed from your site.
markcms Posted July 23, 2013 Author Posted July 23, 2013 You are not listed as a customer which suggests you have not purchased the skin. If this is true, the skin must be removed from your site. my friend bought it
MadMaddox Posted April 8, 2014 Posted April 8, 2014 Its almost been a year, Ehren. Im starting to think he's probably not gonna get back to you with his friends name.
