Wo2dy Posted May 18, 2013 Posted May 18, 2013 Hi Ehren, I would like to know if you have the 3.1.4 version of your Overlay skin? I would also like to know if you know what is the version of the skin on this site? http://www.invisionbyte.net/ Thank you.
Koby Posted May 18, 2013 Posted May 18, 2013 That forum is clearly running off a fairly old/outdated version of IPB. I'm pretty sure Ehren mentioned before that older versions of skins are no longer available.
Wo2dy Posted May 18, 2013 Author Posted May 18, 2013 That forum is clearly running off a fairly old/outdated version of IPB. I'm pretty sure Ehren mentioned before that older versions of skins are no longer available. No because I currently have Marble and there are the versions 3.2.x, 3.3.x and 3.4.x.
Solution Ehren Posted May 19, 2013 Solution Posted May 19, 2013 The 3.1 versions of Overlay are available in the customer area, however I do not offer support with bug fixes or modifications since they are EOL. 1
