Rookie in need of some help
Hello IFS. Sorry if this isn't in the right category, I couldn't find anything more appropriate.
Pardon my English if there any mistakes in this thread. I'm a rookie in general web design and am helping out a friend's community with anything I can. He bought the Animate skin and after some planning, we came up with a neat custom banner for it.
Our problem is, we want to disable the marquee animation that makes it scroll from side to side.
Is there any way to disable it?
Thanks in advance.
Your friend needs to log in here with the username and password he used when buying the skin. Tell him to write in this topic, then he'll get help.
As Semel mentioned, support is only offered to those who have purchased the skin. If your friend signs into his account on this site and posts in this topic, I'll be happy to help him/her out. :)
