The promenu mod isn't installed on my development board so unfortunately I can't say for sure. The skin supports all of the official IPS addons, however it's simply far too much work to support any 3rd party mods/hooks, especially when numerous updates are released by their authors.
You're welcome to wait for a reply from someone who uses both Subway + ProMenu though. :)
  • 4 weeks later...
As long as the skin has all the hook positions still in place, then it should work just fine.
You might need to tweak the colours etc.
I assume that all Ehren's skins keep all the hook points in place.
  • 4 weeks later...
ProMenu should work fine with the theme, the #primary_nav is still used in the theme to allow support for it. However you will need to ensure you have enough HTML and CSS knowalge to make the desired modifications work (icons on the top). Otherwise nothing should break with the theme to my knoweldge.
CSS edits may be required if the add-on also has it's own stylesheet. Which i believe it does from my exsperiance with the application. But those are only simple color changes (if any).
Regards,
Scott
  • 1 year later...
For future reference on this thread being searched. I indeed use both the Subway skin and also the ProMenu Modification. They work fine together. Just don't use the "Icon" option in the Promenu menu item setup Itself or you end up with TWO icons ie "Members" as seen below:
I deactivated all menu options for the "More" with the skin options. The above menus are all made within the ProMenu interface. The custom Twitch Icon was a little harder to get working.
I hope this helps anyone out for information as Subway is a great skin that seems to just allow all other mods smooth use without breakages as seen above! (I wouldn't consider two icons a "break" either, if anything it's an extra icon option :D WIN!)
