Does Uniform work with Promenu?
Go to solution Solved by Azounstone,
Hi Roger,
Unfortunately I'm unable to confirm that all 3rd party addons will work with my skins. They're usually heavily modified (particularly the navigation), so there is always a chance that issues may occur.
If anyone has installed promenu with Uniform, let me know! :)
Thanks for the feedback, Azounstone! When you say adjust CSS, did you ask IPBForumSkins or ProMenu author?
Also, do you have your site so I can reference the look? Thanks in advance.
  • 10 months later...
Hi Roger,
It works fine :)
