Keltix Posted January 10, 2007 at 11:58 PM Posted January 10, 2007 at 11:58 PM Hi, i recently purchased Dimension Green From you guys! i installed it it runs fine... my only problem is.. the template is not a fixed size each time i goto a different topic the board resizes its self its not a FIXED size.. For an Example This is the Index And This Is Inside a Root Forum Can Anyone Tell Me How To make The Forum Fixed To Where It Does Not Resize all the Time?
Keltix Posted January 11, 2007 at 12:53 AM Author Posted January 11, 2007 at 12:53 AM Also i would like to add like 150px of width to the index is this possible?..
Ehren Posted January 11, 2007 at 10:54 PM Posted January 11, 2007 at 10:54 PM It appears as though one of your mods has changed the template (shoutbox, welcome back box, etc). We only support the skins if they have not been modified by customers. The regular Dimension Green skin works perfectly for me, so it must be a problem on your end.
