henrylin680 Posted August 1, 2012 Posted August 1, 2012 Are we able to disable the background function and have a set background for everyone (guest, members, admins)? Is it compatible with mods such as promenu? Can we switch the forum topic view to original default vertical? Does it have separate backgrounds if we want a custom one? Meaning a separate branding/header background, and then regular bottom background? Are we able to replace the gradient or take it off completely? These are the questions I have before I buy. The theme looks great, and I can't wait to try it!
Ehren Posted August 2, 2012 Posted August 2, 2012 Hello, To answer you questions: 1. Yes 2. Compatibility with 3rd party mods is not guaranteed. Support may be given, however I cannot promise a solution in all cases. 3. Yes - there's a tutorial for this in the customer area 4. The skin was designed to have one header background, with the rest of the skin being white. It is possible to have an image for the header and another image for the background, but there may be some odd looking areas since the skin was designed to be white. 5. The gradient is part of the header image. If you edit that image, the gradient can be removed. Hope that helps!
henrylin680 Posted August 2, 2012 Author Posted August 2, 2012 Perfect. Thanks for the quick reply Ehren, will be testing few stuff in firebug inside the demo, and then buying. 1
