avrelob Posted April 28, 2012 Posted April 28, 2012 I'm interested in buying this skin, but I had a few questions about it before I decide. 1. Is there a way to change the backround, I think it's an image by default.. I'm not sure though. How easy would it be to change it? 2. Is it easy to change it back so the poster's information is on the side rather than the top when viewing a topic? 3. It works for Portal right? I can't see it on the demo. Thanks.
Ehren Posted April 29, 2012 Posted April 29, 2012 Hello, 1. Yep - it's just an image so it's very easy to change. 2. It's possible, after a few HTML edits.. 3. Yep, should work fine with most addons.
avrelob Posted April 29, 2012 Author Posted April 29, 2012 Hello, 1. Yep - it's just an image so it's very easy to change. 2. It's possible, after a few HTML edits.. 3. Yep, should work fine with most addons. Thanks. Is there any particular reason you're not accepting registrations on the test board?
Ehren Posted April 30, 2012 Posted April 30, 2012 Some spam bots got through, so it was becoming a hassle to manage.
avrelob Posted May 3, 2012 Author Posted May 3, 2012 Some spam bots got through, so it was becoming a hassle to manage. One more question about Concise.. The side buttons on it, is there a way to make custom tabs that redirect to whatever link you want? And also replace the image thats on the side?
Ehren Posted May 3, 2012 Posted May 3, 2012 Of course There's already a tutorial in the customer area for changing the icons, and the same tutorial could be used to add your own custom link.
