prof Posted December 15, 2011 Posted December 15, 2011 Just wondering because I don't really know... if I purchase a forum skin, if it is put on my website will it have all the controls and options for making posts in a forum? Or is it just something else I don't reallly know? I had a new website made and the developers completely hosed the forum section and I'm trying to get a forum that works so that i can assign permissions to certain areas, and people who are registered can make posts etc.. Thanks.
timestandstill Posted December 15, 2011 Posted December 15, 2011 These skins are for IPBoard. http://www.invisionpower.com/products/board/
prof Posted December 15, 2011 Author Posted December 15, 2011 thanks for the reply, so what that means is that I would have to buy something from IP board, then add this skin to that?
Ehren Posted December 15, 2011 Posted December 15, 2011 Yes. The skins here are only designs (images, colours, etc). If you want an actual forum (where people can post), you need to purchase IP.Board from www.invisionpower.com Once the forum has been installed, you can then use the designs found on this site.
prof Posted December 15, 2011 Author Posted December 15, 2011 Yes. The skins here are only designs (images, colours, etc). If you want an actual forum (where people can post), you need to purchase IP.Board from www.invisionpower.com Once the forum has been installed, you can then use the designs found on this site. thank you, I will look into this. Appreciate the help greatly.
