Ehren Posted October 19, 2011 Posted October 19, 2011 All 3.2.3 skins will also come with the Settings file, allowing you to easily customize certain areas of the skin by turning on/off different features (tooltip forum descriptions, guest message, navigation dropdown menu, social icons, basic topic view, etc). Update: All skins are now compatible with 3.2.3 5
kysil Posted October 19, 2011 Posted October 19, 2011 Is the skin "Uniform" would not be compatible with version 3.2.3?
alexp999 Posted October 19, 2011 Posted October 19, 2011 Is the skin "Uniform" would not be compatible with version 3.2.3? It will probably work but not fully, you just need to wait as Ehren has said: The following list will be updated when the 3.2.3 version of the skin is available.
IanW Posted October 19, 2011 Posted October 19, 2011 As revisions may even happen to the release of 3.2.3 I would wait until the weekend or Monday anyway.
Ehren Posted October 19, 2011 Author Posted October 19, 2011 I can confirm that there will be a few bugs if you use a 3.2.2 skin on a 3.2.3 forum. I would suggest waiting for the skins to be upgraded before upgrading your forum. 1
loz Posted October 19, 2011 Posted October 19, 2011 All 3.2.3 skins will also come with the Settings file, allowing you to easily customize certain areas of the skin by turning on/off different features (tooltip forum descriptions, guest message, navigation dropdown menu, social icons, basic topic view, etc). So will this be a new feature on Overlay Blueberry Ehren? I mean in that it would probably be worth adding our edits to a 3.2.3 fresh version as opposed to adding edits to our current one?
Gaffney Posted October 19, 2011 Posted October 19, 2011 I'm interested, I have two skins on my site I did myself with no html changes on css. When I upgrade my site are changes made automatically or do I have to apply the changes myself ?
Ehren Posted October 19, 2011 Author Posted October 19, 2011 I'm interested, I have two skins on my site I did myself with no html changes on css. When I upgrade my site are changes made automatically or do I have to apply the changes myself ? If the HTML template file is unmodified, it'll automatically upgrade.
Ehren Posted October 20, 2011 Author Posted October 20, 2011 Deflection, Engraved and Uniform now available for 3.2.3 1
Ehren Posted October 20, 2011 Author Posted October 20, 2011 Baisik, Chamelon, Infinite, Infinite Dark and Splat now available.
senators244 Posted October 20, 2011 Posted October 20, 2011 I literally just bought Gravity Blue, and and already had my forums upgraded before I even knew about this place. Anyway If you could get Gravity done for 3.2.3 that would be amazing, because at this point, I'm getting sql errors when trying to import the 3.2.2 version, so right now I can't even use the theme
Ehren Posted October 20, 2011 Author Posted October 20, 2011 Check the tutorials section in the customer area
iPrototype Posted October 20, 2011 Posted October 20, 2011 Thank you for all the work Ehren! You provide a great service and EXCELLENT customer support. So happy I came here
JC99 Posted October 21, 2011 Posted October 21, 2011 I just bought Imperial 2 days ago and it is not on the list. Can you please update it to work with 3.2.3. Thanks
Ehren Posted October 21, 2011 Author Posted October 21, 2011 I just bought Imperial 2 days ago and it is not on the list. Can you please update it to work with 3.2.3. Thanks You may want to re-read the first post.. All skins will be upgraded, but it takes time. 1
JC99 Posted October 21, 2011 Posted October 21, 2011 You may want to re-read the first post.. All skins will be upgraded, but it takes time. I re-read the first post and it says "The following list will be updated" but Imperial is not on that list. I'm in no rush, I was worried I just spent money on a skin that is now obsolete.
Graeme Posted October 21, 2011 Posted October 21, 2011 I re-read the first post and it says "The following list will be updated" but Imperial is not on that list. I'm in no rush, I was worried I just spent money on a skin that is now obsolete. I can assure you, Imperial will be updated within a few days. Ehren is obviously working as fast as he can.
JC99 Posted October 21, 2011 Posted October 21, 2011 I can assure you, Imperial will be updated within a few days. Ehren is obviously working as fast as he can. ok, great. no rush, take your time
Ehren Posted October 21, 2011 Author Posted October 21, 2011 I re-read the first post and it says "The following list will be updated" but Imperial is not on that list. I'm in no rush, I was worried I just spent money on a skin that is now obsolete. Re-read again. It means: I will update the list when each skin is available for 3.2.3. The list originally started with just Carbon (because that was the only skin which I had finished upgrading for 3.2.3). When I upgrade Imperial, it will be added to the list. The list isn't a list of skins which will be upgraded. It's a list of skins which I have finished upgrading, and obviously the rest (which aren't currently on the list) will be added when they have been upgraded I will be as clear as possible - ALL skins will be upgraded to 3.2.3 2
Ehren Posted October 21, 2011 Author Posted October 21, 2011 Navia, Gravity & Overlay upgraded for 3.2.3
JC99 Posted October 23, 2011 Posted October 23, 2011 The list isn't a list of skins which will be upgraded. It's a list of skins which I have finished upgrading ok, I thought that was the list of skins to be upgraded. I will be as clear as possible - ALL skins will be upgraded to 3.2.3 Thanks for the clarification.
