Hi,
I'm not seeing shoutbox on this mobile skin...I'm gonna go out on a limb and say it hasn't been coded ?
Anyhow interested in the new Slate <-- mobile but require shoutbox, so my question is does slate have support for shoutbox ?
If not is it possible to get support for shoutbox ?
Thank you much appreciated.
The slate skin is based on the default mobile skin. If the shoutbox isn't compatible with the default skin, it won't be compatible with the Slate skin.
You'll probably need to ask the author of the shoutbox about adding it to the default mobile skin. You can use the same technique/steps on the slate skin. :)
