Miikle Posted March 23, 2011 Posted March 23, 2011 I've got to say, this is the best theme creation service I have used in all my years as a web developer. The themes are so smooth and clean and the service is just amazing! Quick, easy to understand and straight to the point. And the prices, for someone with a tight budget such as myself, are the best around (and yes, I've definitely been looking for value for money themes). I think IPB Forum Skins will give Invision that leg up it needs to be able to gain more popularity over vBulletin and XenForo as these themes are just so attractive! I would recommend this site to anyone starting out with a new forum! We hope to use your services in the near future! -Genrol.net
Ehren Posted March 23, 2011 Posted March 23, 2011 Thanks Miikle - much appreciated. Glad you like the skins!
Cyrem Posted March 23, 2011 Posted March 23, 2011 And the amazing thing is... it's all done by one guy! .. well I've never seen anyone else.
Feneroin Posted March 23, 2011 Posted March 23, 2011 and Thanks from me. I have bought 2 skins and always happy in the future, i think a custom skin also
tsigo Posted March 23, 2011 Posted March 23, 2011 Truth. I looked at a lot of skins and skin sites before finding you and all of the other skins were either garbage or had some fatal usability problem. IPS should really consider subsidizing you, because you're one of the few people making their software look better.
