GrooveJunkie Posted February 21, 2011 Posted February 21, 2011 Hi, I noticed the infinate skin has a customizable interface feature for users to change colors to suit their tastes. I wanted to know if it was possible for the admin to use the customizable interface to set the colors and then not allow users to use this feature, is this possible? Also, it is possible for a test of this feature ( customizable interface ) please.. Its not available see it on the demo board? thanks you in advance Gold
Ehren Posted February 21, 2011 Posted February 21, 2011 The default colour can be changed by the admin, and the customize feature can be removed if required.. The customize feature is available on the demo board.. are you having any problems with it?
GrooveJunkie Posted February 22, 2011 Author Posted February 22, 2011 thanks Ehren I have managed to work out where the customize feature is located so not a problem
TerenceBloodcaliburSanchez Posted September 19, 2011 Posted September 19, 2011 Exactly where is the setting to which you can change the default color for Infinite?
Ehren Posted September 20, 2011 Posted September 20, 2011 Support for premade skins is only offered in the Customer area for members who have purchased the skin.
