Vini Posted February 11, 2011 Posted February 11, 2011 Hi, I've recently taken over our IPB forum that uses the checkered skin since our previous admin has disappeared on us. I've just upgraded our board from 3.0.1 to 3.1.4 and now we are seeing some issues. Where can I download and updated version of the checkered skin for our board? Please advise.
nodle Posted February 11, 2011 Posted February 11, 2011 It should be in your customer downloads. The button can be found on this forum at the top right. But since it doesn't show that you are a customer, you may not have access to it. You may need to log in under your old admins account, or wait to see what Ehren says.
Ehren Posted February 11, 2011 Posted February 11, 2011 Do you know the username of your other admin on these forums? Or his paypal address? Or standard email address?
Vini Posted February 12, 2011 Author Posted February 12, 2011 yes I do...I'll PM it to you if that helps
Vini Posted February 12, 2011 Author Posted February 12, 2011 OK...got the new files downloaded. I'm not exactly sure what steps to take to update our skin. How can I update it and preserve the banner logo and navigation buttons we have customized? I tried using the import option and selected 'upgrade existing skin' when it it finished it had added a new skin set called 'Checkered(imported)'. Any tips or suggestions would be much appreciated. Thanks!
Ehren Posted February 12, 2011 Posted February 12, 2011 You'll need to import it and redo your modifications. The upgrade feature won't work for 3.0.x to 3.1.x as far as I know.
