twilightwarrior Posted February 8, 2011 at 07:07 AM Posted February 8, 2011 at 07:07 AM I love you blueberry skin... does it support IP. Content and IP. Portal?
Ehren Posted February 8, 2011 at 12:21 PM Posted February 8, 2011 at 12:21 PM It currently supports the portal but will not fully support IP.Content until the next update. The skin will work with IP.Content, but some modifications may be required
twilightwarrior Posted February 8, 2011 at 12:42 PM Author Posted February 8, 2011 at 12:42 PM If I buy the skin can I get a free upgrade to the next version? Do you install it for me? Also I love your shout box! Where can I get THAT one?
Ehren Posted February 8, 2011 at 12:45 PM Posted February 8, 2011 at 12:45 PM Upgrades to 3.2 will be free. Installation is available if needed, and the shoutbox can be downloaded from the Invision forums
twilightwarrior Posted February 12, 2011 at 08:39 AM Author Posted February 12, 2011 at 08:39 AM Which shout-box is it? I tried one and it was awful!
Ehren Posted February 12, 2011 at 11:46 AM Posted February 12, 2011 at 11:46 AM http://community.invisionpower.com/files/file/2285-shoutbox-113/
twilightwarrior Posted February 15, 2011 at 10:30 AM Author Posted February 15, 2011 at 10:30 AM Thanks! Do you know what the key to installing it is? Is there some yes no option somewhere? Thanks for all the help by the way!
Ehren Posted February 15, 2011 at 02:14 PM Posted February 15, 2011 at 02:14 PM Not entirely sure what you mean..
twilightwarrior Posted February 15, 2011 at 06:26 PM Author Posted February 15, 2011 at 06:26 PM I'm just a little confused by it. I uploaded the files but no shoutbox appears and I don't see a place where I can active or install it. Is the on switch under System Settings, Manage Applications & Modules? Thanks again for all the help. Its great to talk to someone who already has it installed!
Ehren Posted February 18, 2011 at 07:04 AM Posted February 18, 2011 at 07:04 AM Any support for the shoutbox should be asked at the Invision forums
twilightwarrior Posted February 18, 2011 at 07:39 AM Author Posted February 18, 2011 at 07:39 AM Will upgrades beyond 3.2 be free? How often does IPB come with a new version?
Ehren Posted February 18, 2011 at 08:01 AM Posted February 18, 2011 at 08:01 AM Upgrades to 3.2 will be free.
