Overdrive Posted December 17, 2010 Posted December 17, 2010 It's me again I managed to work on IPB on my home pc with wamp a lot before but with a clean install. Today I tried to copy my sites database (1gb) into wamp wich was a pain in the a but it worked, and configured phpmyadmin, my conf_global file and it almost works. The only problem is there is no text nor in the front end nor in the backend I think I messed up somewhere in the database setup. Any ideas? *Meanwhile I did a clean install too to see if that works and it does, I copied the new and clean forums conf_global.php to the non working forum and changed only the things that are necessary (board url, database name) and it still has no content
darkrisingx Posted December 18, 2010 Posted December 18, 2010 I use wamp a lot of my server here at home and no problem. Having a hard time getting what you mean. If you are uploading your database does it go without a problem. I no wamp by default does not take a 1gb file unless configed which is a pain. I can give a command that will import the database with cmd in one pass if thats the problem. Or if the site is showing a database error are you typing the right info in the default username for the database is root and no password then the database name is what you made.
