Light & Dark mobile skins
Hi everyone,
Just a quick update regarding the slate mobile design. I had quite a few requests for a neutral color scheme (black and white) as well as a darker version of the skin. These two new versions of the skin have just been released and are available on the original slate skin page.
Slate is a skin designed specifically for mobile devices. The skin is designed heavily around css3, including gradients, text shadows, rounded corners and animations - and has very few images. The layout is user-friendly, has been coded efficiently and provides an enhanced layout over the default mobile design which comes with 3.1.x.
  • 2 weeks later...
I would like to see a version that matches or is tied to the overlay red colour (i suggest it might be a good idea to make mobile colour theme's similar to your full blown IPB skins) cross-selling and upselling available then :)
New mobile colours will be introduced - I'm just flooded with custom work at the moment and am trying to finish up on 2 other premade skins. Once they're all done, new colour versions should be ready..
Custom mobile skins are also an option if you need a specific colour scheme.
