Hi,
is it possible to get the Baisik Skin with a fluid width?
Furthermore is it possible to also apply the skin to IP.Content?
Thanks,
Andreas
The baisik skin is very much fluid however it has a set min and max width and a percentage of the board.
These are easily changed.
The skin can be used with IP.Content if you're using the board wrapper - if not it would take more work to skin IP.Content to the same sort of style.
