jfcguy Posted July 2, 2010 at 09:46 PM Posted July 2, 2010 at 09:46 PM Good day: After scanning your site for a month I've really enjoyed reading the positive feedback about your work and your dedication to your customers requests. I'm considering purchasing at least one skin - but before I would really like to see the Chameleon and Checkered skins live if possible. Also here are my questions about both skins: If I'm not using the gallery, downloads, blog or portal options - can they be removed and will everything then shift to the right or left? If so - is that an option to re-add these in the future? Can the width and length of the logo on top be changed to a larger image or a flash file as well? Thanks in advance.
Ehren Posted July 3, 2010 at 01:42 AM Posted July 3, 2010 at 01:42 AM Hello, I've PMed you with a demo of both skins. If you don't have any of the components, they simply won't show in the skin. It's all automatic, so if you decide to add a component in the future, a link will appear in your navigation. The skins work exactly the same as the default skin in that aspect. The logo's are easy to modify. Some of the skins can't have logo's which are too wide because it may interrupt the navigation (ie. you can't have a 100% width logo on chameleon since the navigation is to the right of the logo). However they can be changed easily, and flash files can be used.
