Hello! :)
I would like to ask a few questions about the Chameleon skin. Im about to purchase this skin next week and wonder if it's possible to have the background image fixed in the same position as seen in the Carbon series? If so would I get help with that as a customer as I dont have a clue what would be needed?
I also wonder if it's ok to change the category icons as in the Chameleon skin the coffee cup is not my personal...cup of tea so to speak. ^_^
Regards
/UpNorth
Yes, changing the background to a fixed image is no problem. There may be some browser lag when scrolling depending on the size of your background image and how many categories you have (each category uses transparent png images to create the shadow effect, so if you have lots of categories, there's a lot of transparent work happening). I've only seen the issue on Firefox on windows (there's a slight delay when scrolling the window, and seeing the actual page scroll), but it also depends on your configuration if your computer can handle it. :) Apart from that, there are no problems.
The icons aren't included with the actual skin, but there's a tutorial in the customer section telling you how to add them. :)
