This is most likely in the wrong section, If so feel free to move it.
We have done some basic modifications to the "Green Carbon" skin and this is the result thus far.
http://HolyMods.com
We have plans to edit it further and we will keep you updated with how it looks.
~Scott
Looks nice :) I'd suggest changing your background image from a transparent png to a solid jpg. The png image is 1.5MB in size which can take some time to download depending on your connection. :)
Double post, but thank you for the tip.
We brought our background from 2mb to 0.5
My users have noticed a great increase in speed and an increase in load times on mobile devices :thumbs:
Nice to hear.
PNG's should only really be used if transparency is needed. If they can be avoided for large images, then jpg's are generally the better way to go. :)
