MiketheQM Posted January 15, 2010 Posted January 15, 2010 Once again I find these "smileys" to be less than interesting. The IPB defaults always look crappy over the awesome dark background of the skins so I'm off to get some good ones. Any suggestions on where I should pick a set up at? Hopefully a set to make it easier. I'm not cropping 20 of them while trying to match the background again. That was a nightmare and it ended up looking terrible anyway.
nodle Posted January 16, 2010 Posted January 16, 2010 The easiest solution is to use .png smilies that way they blend with every type of background.
Eternal Posted February 12, 2010 Posted February 12, 2010 The easiest solution is to use .png smilies that way they blend with every type of background. If only the majority of emoticon creators were that smart. =\
