Square Wheels Posted July 30, 2025 Posted July 30, 2025 When final is released, any theme updates needed for the ones you've released at this point?
Ehren Posted July 31, 2025 Posted July 31, 2025 Yeah, Uniform will need an update due to the way Javascript is processed in the backend. I'll release it shortly so it's ready for the .10 update 2
Square Wheels Posted July 31, 2025 Author Posted July 31, 2025 9 hours ago, Ehren said: Yeah, Uniform will need an update due to the way Javascript is processed in the backend. I'll release it shortly so it's ready for the .10 update Speaking selfishly, thanks. I use illuminate, so I assume I'm all set.
bags_ppp Posted August 4, 2025 Posted August 4, 2025 I installed 5.10 and only then found this issue. Now people can not change theme. Is there maybe some quick fix with custom css before version for 5.10 is released? Thank you.
Ehren Posted August 4, 2025 Posted August 4, 2025 1 hour ago, bags_ppp said: I installed 5.10 and only then found this issue. Now people can not change theme. Is there maybe some quick fix with custom css before version for 5.10 is released? Thank you. Yes
