Adhack Posted April 2, 2024 Posted April 2, 2024 I have some questions here regarding the template, how does the customization part work? Is it too complex to customize a template? And the question of the amount, is it 30 dollars monthly or every 6 months?
Solution Ehren Posted April 2, 2024 Solution Posted April 2, 2024 Hi there, Customization can be done in 2 ways. The first is by changing settings in the admin panel. This technique can be used to change colors, logos and to enable/disable certain features. For everything else, you’ll need to add some custom CSS code to your site. If you need help with the code, you can just ask on the support forum and I’ll be happy to assist. The themes are $30, and then $10 every 6 months ($20/year) which gives you access to the updates. If you cancel your subscription, you can keep using your theme. You just won't have any access to support or the latest update until you renew again. You will also need Invision Community installed on your server (or you can use one of their cloud plans). These themes will not work without it. So make sure you’re using that before purchasing any of the themes I hope that helps!
