Following this announcement from earlier this week, there was in fact one template update for Invision Community 4.7.15 😅
The change log is:
- Upgraded for Invision Community 4.7.15
- Made dropdown menus move obvious when they’re placed inside existing dropdown menus (eg, “My Details” menu)
All themes have since been updated and are available in the Client Area for all active subscribers 🙂
  • Thanks 5
I think you meant moRe there. 😋
  • Haha 1
4 hours ago, Square Wheels said:
Silly question, I am staying on 4.4.14 for a while.  Waiting for other app updates.
Can I install the new version of the themes?
You should only install these themes if you’re upgrading your software. If you’re still on 4.4, stick with the 4.4 theme.
Hi Ehren,
thanks for pointing out, so in our case with custom template the change is minimal as well.
We are based on Shift, at least at some point it started with Shift :)
Thanks,
Thomas
  • Ehren locked this topic
