Hi everyone,
The only update for 4.7.11 relates to an {{if}} statement for the "guest terms bar". To apply the update for yourselves, first upgrade your software and then open the globalTemplate file. Find:
if="!\IPS\Member::loggedIn()->member_id and \IPS\Settings::i()->guest_terms_bar"
Change to:
if="\IPS\Settings::i()->guest_terms_bar"
This update appears to let the guest/cookie message be displayed to logged in members in certain situations. A theme update will be available over the next few days which will include the updated code, however if you're comfortable editing the above code yourself, feel free to do it since no other changes will be included in the update.
I hope that helps! 🙂
  • Thanks 1
Seems like the workaround doesn't work, at least in my skin (Brave). I've also tried it with other test accounts and on other platforms. 🤔
My apologies, there’s also a small modification for the footer file which adds that link.
I’ll update the themes over the next few days 🙂
Thank you, @Ehren. There seems to be a bigger problem with the last update anyway, which has to do with the cookie revision. In any case, the official forum is already in a state of great excitement. 😄
Can you post the changed code for the footer please @Ehren It might be quicker for me to apply that edit too and wait until the next bigger update to upload the themes again!
