Ehren Posted December 3, 2022 Posted December 3, 2022 Hi there, Thatโs just a static HTML/CSS menu which has been added to the globalTemplate file. ย 1
Maqlao Posted December 4, 2022 Author Posted December 4, 2022 3 hours ago, Ehren said: Hi there, Thatโs just a static HTML/CSS menu which has been added to the globalTemplate file. ย Could you share the code please?
Ehren Posted December 4, 2022 Posted December 4, 2022 I don't typically share those bits of code since I designed and coded them specifically for this site, but you're welcome to inspect the code and use it for inspiration for your own layout if you wish 2
Maqlao Posted December 4, 2022 Author Posted December 4, 2022 1 hour ago, Ehren said: I don't typically share those bits of code since I designed and coded them specifically for this site, but you're welcome to inspect the code and use it for inspiration for your own layout if you wish I'd like a start, but I'll take it from there.
