zlitz Posted November 11, 2021 at 01:04 AM Posted November 11, 2021 at 01:04 AM Hey guys I just wanted to know if any of you know how to change the URL slug "forum". I currently host my IPS forum on a /forum URL to my main domain so it creates two "forum" when clicking a category Video: https://streamable.com/r6t6kh
Ehren Posted November 11, 2021 at 04:31 AM Posted November 11, 2021 at 04:31 AM I imagine this would require significant code modifications. I unfortunately don't have an answer for that, sorry! 1
zlitz Posted November 11, 2021 at 12:07 PM Author Posted November 11, 2021 at 12:07 PM Ah gottcha! Figured I'd ask
Freddie M Posted December 1, 2021 at 01:47 PM Posted December 1, 2021 at 01:47 PM You can change the FURL's via the ACP. Search FURL in the ACP, then click "[System] Customize Friendly URLs". @zlitz: Then search the FURLs for 'forum' in the "Search Friendly URLs" box. You can then tweak the default URL for the forums' app. Just keep in mind you will most likely require editing the topic URL and others. I have mine set to something different. If this doesn't work, there's another trick, but it involves resetting all your existing changes, but I assume you haven't added any. 1
Ehren Posted December 1, 2021 at 10:27 PM Posted December 1, 2021 at 10:27 PM Nice Joey, thanks for the help! 1
zlitz Posted December 12, 2021 at 08:13 PM Author Posted December 12, 2021 at 08:13 PM On 12/1/2021 at 1:47 PM, joey_m said: You can change the FURL's via the ACP. Search FURL in the ACP, then click "[System] Customize Friendly URLs". @zlitz: Then search the FURLs for 'forum' in the "Search Friendly URLs" box. You can then tweak the default URL for the forums' app. Just keep in mind you will most likely require editing the topic URL and others. I have mine set to something different. If this doesn't work, there's another trick, but it involves resetting all your existing changes, but I assume you haven't added any. I have a feeling this isn't what I am meant to do
Freddie M Posted December 13, 2021 at 04:41 PM Posted December 13, 2021 at 04:41 PM 20 hours ago, zlitz said: I have a feeling this isn't what I am meant to do I don't see your default forum URL in this screenshot. Have you already tried to change it? The Real URL would be "app=forums&module=forums&controller=index" If you would like, I wouldn't mind taking a look for you? PM your URL and ACP creditials, I'll take a look and hopefully sort it out for you.
picasso Posted December 13, 2021 at 07:55 PM Posted December 13, 2021 at 07:55 PM On 11/11/2021 at 2:04 AM, zlitz said: I currently host my IPS forum on a /forum URL to my main domain so it creates two "forum" when clicking a category Check also this post: https://invisioncommunity.com/forums/topic/404954-friendly-url-work-good/#comment-2512778
zlitz Posted December 16, 2021 at 07:27 PM Author Posted December 16, 2021 at 07:27 PM On 12/13/2021 at 4:41 PM, joey_m said: I don't see your default forum URL in this screenshot. Have you already tried to change it? The Real URL would be "app=forums&module=forums&controller=index" If you would like, I wouldn't mind taking a look for you? PM your URL and ACP creditials, I'll take a look and hopefully sort it out for you. Dm'd!
