dreamlander Posted September 30, 2021 Posted September 30, 2021 Hi, I want to purhchase a theme, but I have an old version of ips 4.5.4, I noticed that all your themes are updated to v.4.6. so, is it compatible with the old ips versions? Thank you!
Solution Ehren Posted October 1, 2021 Solution Posted October 1, 2021 Hi @dreamlander You can download 4.5.x versions of every theme except for illuminate, which was coded for 4.6 and above. With that said, future theme updates will only be compatible with 4.6, so I would suggest upgrading at some point if possible
