Ehren Posted September 6, 2009 at 05:40 AM Posted September 6, 2009 at 05:40 AM All of the premade skins have been upgraded to IPB 3.0.3 (as well as the most recent versions of blog and gallery). If you upgrade to 3.0.3 and would like the updated files, just send an email through and I'll send through the updated skin
Hyperz Posted September 6, 2009 at 11:17 AM Posted September 6, 2009 at 11:17 AM Ah sweet, mail on its way .
SgtTech Posted September 6, 2009 at 04:55 PM Posted September 6, 2009 at 04:55 PM I just sent an email to you as well...
Trancehed Posted September 22, 2009 at 05:24 AM Posted September 22, 2009 at 05:24 AM emailing.. Is there a big reason to update them btw? Do we need to if we don't find any bugs? You've helped me with a decent amount of whitespace issues.. and changing the way the buttons display.. And when I upgrade I have to redo these steps. I'm not even sure I remember how to right now. Just wondering how important upgrading the skins is..
Ehren Posted September 22, 2009 at 06:29 AM Author Posted September 22, 2009 at 06:29 AM The upgraded skins aren't vital for your board to work.. but there are a few bugs/features fixed with the updated skins. There are instructions in the customer forum on how to manually upgrade your skin if you've already modified it.. Otherwise if you install the updated version, it will remove all of your previous skin modifications..
Trancehed Posted September 22, 2009 at 06:34 AM Posted September 22, 2009 at 06:34 AM Looks like doing a manual upgrade will probably be harder. Thanks I'll email you for the updated files
