Brek Posted June 21, 2021 Posted June 21, 2021 Hi, im a customer but dont have access to the "customer only" forums. I just buyed the Subway theme from de Marketplace on my ForumAdmin (Order #154077). I have this error when the theme was automatic installed: [[Template core/front/global/userBar is throwing an error. This theme may be out of date. Run the support tool in the AdminCP to restore the default theme.]]
Solution Brek Posted June 21, 2021 Author Solution Posted June 21, 2021 Nevermind. I think this error is because im using 4.5 instead of 4.6. But even so, i would like do have access to the customer only forums.
Ehren Posted June 21, 2021 Posted June 21, 2021 Hi Brek, Welcome to ipsfocus. That's correct - using a 4.6 theme on the 4.5 software will cause that error. I'm glad you were able to upgrade your software I've updated your account to customer status, so you should now have access to the full site!
