RocketFoot Posted October 16, 2020 Posted October 16, 2020 I am working on sticky nav bars and swapping quick search with Userbar on default theme and everything looks good so far except I have a big problem with the username and create dropdown menus! You can click them and the dropdowns display nicely but as soon as you roll your mouse down to select a menu item, the menu closes without a click! It does the same thing for guests trying to click Sign in! I have been messing around with this for hours and I can't find the problem (CSS is not my specialty!) Here is the URL for my test board: https://7173mustangs.com/ipstest/ Click on Sign In to see the problem...
Ehren Posted October 17, 2020 Posted October 17, 2020 Hello, The relocating of the user panel into the navigation bar has likely caused this. The navigation menu uses javascript to show/hide dropdown menus, and that is likely conflicting with the user panel dropdown menus. Since you're using the default Invision theme and not an ipsfocus theme, I unfortunately don't have a simple solution for you, but hopefully that guides you in the right direction
RocketFoot Posted October 17, 2020 Author Posted October 17, 2020 Thanks for the reply! I heard you were the authority on sticky nav bars so I figured I'd ask! I do like your Dimension theme, I just hate to add another license fee to my yearly bills right now! 1
