Ehren Posted August 20, 2019 Posted August 20, 2019 Hi everyone, If you're using the latest version of your IPSfocus theme (from June 22), you don't need to upgrade it for 4.4.6 since there are no template changes required If you are using an older version of your theme/software and you want to upgrade, I would suggest downloading and installing the most recent version from the Client Area. 3 1
Ehren Posted August 22, 2019 Author Posted August 22, 2019 Hi @biaggi Have you ever used the "Upload new version" feature in the past? If so, it's likely that your theme wasn't upgraded correctly, which is resulting in the above message. In this situation, I'd suggest downloading the latest version of Brave and installing it once you've upgraded your site
