Andy Y Posted January 30, 2019 Posted January 30, 2019 Hi, Is it possible for Admins to upload alternative Background Images and force the change for a user? Is the width easily adjustable (say 95%). Thanks,
Andy Y Posted January 30, 2019 Author Posted January 30, 2019 A further question, pertinent today, is whether this works with 4.4?
Solution Ehren Posted January 30, 2019 Solution Posted January 30, 2019 Hi Andy, Yep, the background images can be changed via the theme settings. The width can be edited using the same theme settings as every other IPS theme (under the Custom tab). The theme is currently only compatible with 4.3. It will be upgraded for 4.4 once the final (non-beta or RC) version has been released I hope that helps - welcome to ipsfocus! 1
Andy Y Posted January 30, 2019 Author Posted January 30, 2019 Thanks Ehren, I'd just had notification that 4.4 is on release now.
Ehren Posted January 30, 2019 Posted January 30, 2019 53 minutes ago, Andy Y said: Thanks Ehren, I'd just had notification that 4.4 is on release now. 4.4 is currently in beta. The themes will be updated once the final version of 4.4 is available
