pure_it Posted September 21, 2018 Posted September 21, 2018 Ehren, Just ready to upgrade to 4.3.6 (from previous version). Plan was to upgrade Chameleon theme first(uploading your new XML), then upgrade the IPB to 4.3.6. So I uploaded the new(4.3.6) XML for Chameleon and now I'm getting an incompatible theme message when I click on Upgrade NOW button core → front → global → mobileNavigation core → front → global → navBarItems core → front → global → userBar core → front → widgets → guestSignUp During the template comparison portion of the upgrade, I did elect to KEEP the core/front/custom/custom.css since I had some custom css there and the only red part was my edit. Is it OK to proceed? thanks
Solution Ehren Posted September 21, 2018 Solution Posted September 21, 2018 Hello, To prevent confusion, the 4.3.6 theme should technically be installed after upgrading your software, however if you installed it first and are now upgrading the software, you can be rest assured it’s just a false positive. The latest version is compatible with 4.3.6 1
pure_it Posted September 21, 2018 Author Posted September 21, 2018 Thanks! I thought I had read some where in one of your guides to upgrade the theme first, then move onto the board. Anyhow, Seemed to work out. thanks again 1
