Ehren Posted May 27, 2018 Posted May 27, 2018 All themes have been updated and released in the Client Area and IPS Marketplace. The change notes for this release are: Minor HTML change for 4.3.3. Subforum columns should now align better Long subforum names are truncated The default font has been changed to system fonts New css variables allow for easier modifications The update also includes bug fixes for anything reported in the customer forums, as always 2
crmarks Posted May 27, 2018 Posted May 27, 2018 If we update the ipsfocus_base.css file with your changes instead of uploading a new version of the theme, should we edit the parent theme or the child theme ipsfocus_base.css?
Ehren Posted May 27, 2018 Author Posted May 27, 2018 The IPS system is still a little bugged (I've reported the issues to IPS already), so I'm not entirely sure on the best method, but I'd probably add the nightly code to the parent theme. The child will inherit it. 1
Ehren Posted May 27, 2018 Author Posted May 27, 2018 Themes have been re-released to fix a system font issue with Chrome on Windows. The nightly file has also been patched for those of you who use that method 1
uA_Y_C_A Posted May 27, 2018 Posted May 27, 2018 8 hours ago, Ehren said: The default font has been changed to system fonts How do we get back to the old font? (Uniform) what is the system font? Is the font on the device we use? If so, what are the benefits?
Ehren Posted May 27, 2018 Author Posted May 27, 2018 1 hour ago, uA_Y_C_A said: How do we get back to the old font? (Uniform) what is the system font? Is the font on the device we use? If so, what are the benefits? Google fonts can be assigned within the theme settings, otherwise just apply your font using normal css. body{ font-family: Tahoma, sans-serif; } The system font is the native font of the device. For Mac and iOS, it's called San Francisco. For Windows, it varies depending on the version. Using system fonts just helps to maintain consistency between your site and the OS you're using. They also load faster than web fonts since they're stored locally. 1 1
Arthmoor Posted May 27, 2018 Posted May 27, 2018 Did IPB give any sort of reason for why they felt this was necessary? None of my users like the change and I can't seem to get it restored to what was there before 4.3.3 without seriously messing everything else up in the process.
Ehren Posted May 27, 2018 Author Posted May 27, 2018 2 hours ago, Arthmoor said: Did IPB give any sort of reason for why they felt this was necessary? None of my users like the change and I can't seem to get it restored to what was there before 4.3.3 without seriously messing everything else up in the process. If you need help with your theme, post in the support area and I’ll be happy to assist. Changing the font is a very easy process
Deltafox Posted June 19, 2018 Posted June 19, 2018 Ipb 4.3.4 Build 103021 is out any change on theme? Regards
Ehren Posted June 19, 2018 Author Posted June 19, 2018 2 hours ago, Deltafox said: Ipb 4.3.4 Build 103021 is out any change on theme? Regards The theme updates will be released tomorrow, but there's only one minor change to the Downloads addon. If you don't use Downloads, you don't need to update 1
Deltafox Posted June 19, 2018 Posted June 19, 2018 41 minutes ago, Ehren said: The theme updates will be released tomorrow, but there's only one minor change to the Downloads addon. If you don't use Downloads, you don't need to update tk's but I use Download.. Regards
Deltafox Posted July 24, 2018 Posted July 24, 2018 Ipb 4.3.5 Build 103028 is out any change on theme? Regards
