AlexJ Posted May 13, 2018 Posted May 13, 2018 Do we seriously need one? I don't think so, but here is one short simple one. Ehren is most dedicated web developer, I have seen so far. Fair and easy to work with. Using his developed themes since last 6-8 years, I think? Yes, super long time. A+ for every thing. 2 1
Ehren Posted May 13, 2018 Posted May 13, 2018 Thanks Alex, appreciate the feedback! That's a very long time too! 1
ajmboy Posted May 26, 2018 Posted May 26, 2018 +1 here and A+ for Ehren! Not only are his premade themes great and packed with features but he also does phenomenal custom work. Ehren has been making custom themes for 4 of my sites for a few years now and I recall one of the sites that I was moving over from vbulletin and was highly customized, he got it to look almost identical using IPS. Really easy to work with. Thank you Ehren for all your work! 1
Ehren Posted May 26, 2018 Posted May 26, 2018 Two Alex's in one testimonial topic, both long term too! Thanks for the feedback guys, appreciate it!
PKIDelirium Posted May 26, 2018 Posted May 26, 2018 Agreed on all, been using Elegant nonstop since 2010 when it was still Skinbox. After upgrading to IPS4, continuing was a no-brainer 1
