Олег Posted July 28, 2017 Posted July 28, 2017 Hi all. The problem with Reactions https://invisioncommunity.com/news/new-reactions-r1016/ when I upgrade forum to 4.2. They are lost and do not appear in the Dispersion 4.x - ipsfocus. In Default Reactions available. Please help!
Solution Ehren Posted July 28, 2017 Solution Posted July 28, 2017 Hello, The Dispersion theme is not yet compatible with 4.2. It'll be upgraded hopefully sometime next week, and the reactions will work just fine 1
Олег Posted July 31, 2017 Author Posted July 31, 2017 Thank you. How can I know that the Dispersion theme is updated and compatible with 4.2? I will need to buy the updates? Or will need to just download the theme? My purchases EXPIRES 08/14/2017
Ehren Posted July 31, 2017 Posted July 31, 2017 You can follow the Facebook or Twitter pages, or the pinned topic in the Client Area which announces all theme updates. You'll receive the update for free since you're an active subscriber. 1
Олег Posted July 31, 2017 Author Posted July 31, 2017 Thank you. I'll wait ) I correctly understood that when the Dispersion update for 4.2, I'll just download the theme and re-install? Will I lose the settings from the old threads Dispersion?
Ehren Posted July 31, 2017 Posted July 31, 2017 Yep, click the green button once the 4.2 version is available and it'll take you to the download page. The 4.2 themes are recoded from scratch, so you'll need to reapply any modifications or settings. 1
Олег Posted July 31, 2017 Author Posted July 31, 2017 Thank you again. I hope that Dispersion theme will be updated as soon as possible.
Олег Posted August 3, 2017 Author Posted August 3, 2017 Hi! "All ipsfocus theme is now compatible with 4.2.x!" Including Dispersion? You can download? =)
Ehren Posted August 3, 2017 Posted August 3, 2017 6 minutes ago, Олег said: Hi! "All ipsfocus theme is now compatible with 4.2.x!" Including Dispersion? You can download? =) Correct 1
Олег Posted August 7, 2017 Author Posted August 7, 2017 Здравствуйте.Новая версия тема не содержит много функций. Например, пункт "разное" отсутствует.
Ehren Posted August 7, 2017 Posted August 7, 2017 Hello, Since ipsfocus is a primarily English site, I'd request that you use Google translate for your next post so others can understand you The settings were intentionally removed. The tutorial forum explains how to achieve missing settings using css methods instead.
Олег Posted April 26, 2018 Author Posted April 26, 2018 Hi. Compatible length the theme of Dispersion 4.2.х. with the new version of IPB 4.3. Or you have to buy the updates of the theme?
Ehren Posted April 26, 2018 Posted April 26, 2018 7 hours ago, Олег said: Hi. Compatible length the theme of Dispersion 4.2.х. with the new version of IPB 4.3. Or you have to buy the updates of the theme? You’ll need to download the 4.3 update from the client area. It’s a free update for active customers. If your subscription has expired, it can be renewed for $10. 1
