Ehren Posted June 26, 2017 Posted June 26, 2017 In addition to Titan and Novus which were released for 4.2.0 a few weeks ago, I've just released 4.2.0 versions of Chameleon (light), Deflection, Shift and Subway. If you're an active subscriber of any of those themes, you can download the 4.2 updates for free from the Client Area. Other 4.2 themes will be released over the coming weeks in a random order depending on when they're finished. If you've taken the plunge into 4.2, feel free to download the themes and let me know what you think! 7
Nebthtet Posted June 26, 2017 Posted June 26, 2017 Here's to hoping for Chameleon Dark as my users whine constantly about light theme we have now hehe
dokdok Posted June 27, 2017 Posted June 27, 2017 One question: If I have not yet installed IPS 4.2 because I prefer to wait for it to be definitive and not Beta, can I still update my skin to version 4.2 or does this work ONLY with IPS 4.2?
Ehren Posted June 27, 2017 Author Posted June 27, 2017 3 hours ago, dokdok said: One question: If I have not yet installed IPS 4.2 because I prefer to wait for it to be definitive and not Beta, can I still update my skin to version 4.2 or does this work ONLY with IPS 4.2? It only works with 4.2. If you try to install a 4.2 theme on a 4.1 forum, expect a multitude of problems. 1
dokdok Posted June 27, 2017 Posted June 27, 2017 Thanks a lot for the fast response ... You're always awesome 1
Ehren Posted July 3, 2017 Author Posted July 3, 2017 1 hour ago, Tunbay said: What about Elegant theme 4.2 release? On 26/06/2017 at 1:31 PM, Ehren said: Other 4.2 themes will be released over the coming weeks in a random order depending on when they're finished.
Freddie M Posted July 4, 2017 Posted July 4, 2017 One of my themes is compatible with the beta, yet my main site uses snapshot which isn't yet. I think it's a great decision to support the betas, as it allows us to upgrade and get things ready for the final release. I have been testing these past few days and a lot of my custom work is actually unbroken which impresses me. Thanks @Ehren 2
Ehren Posted July 6, 2017 Author Posted July 6, 2017 Uniform and Snapshot are now available for the 4.2.0 beta. 1
Freddie M Posted July 6, 2017 Posted July 6, 2017 @Ehren please consider re-adding the guest message I liked using it. Also the ability to fix the header. =)
Ehren Posted July 7, 2017 Author Posted July 7, 2017 1 hour ago, joey_m said: @Ehren please consider re-adding the guest message I liked using it. Also the ability to fix the header. =) The guest message is still available, check the 4.2 tutorials
Freddie M Posted July 7, 2017 Posted July 7, 2017 1 minute ago, Ehren said: The guest message is still available, check the 4.2 tutorials I'm actually seeing some weird behaviour in my 4.2 dev site. If you narrow the width of your site, it also forces the background to show smaller.
Ehren Posted July 7, 2017 Author Posted July 7, 2017 2 minutes ago, joey_m said: I'm actually seeing some weird behaviour in my 4.2 dev site. If you narrow the width of your site, it also forces the background to show smaller. That's probably working as intended. Please post in the customer area if you're having issues since support isn't offered in News topics
Ehren Posted July 7, 2017 Author Posted July 7, 2017 4 hours ago, steve bullman said: any time frame for dimension please? Hello, On 26/06/2017 at 1:31 PM, Ehren said: Other 4.2 themes will be released over the coming weeks in a random order depending on when they're finished. Dimension is currently being coded, however ETA's for themes aren't provided since they can usually take longer than expected 2
Ehren Posted July 9, 2017 Author Posted July 9, 2017 On 08/07/2017 at 5:38 AM, steve bullman said: any time frame for dimension please? Dimension is now available. 1
steve bullman Posted July 9, 2017 Posted July 9, 2017 Cool. I'm finally going live with ips next weekend, wondering if I should do it with 4.2 You have seen my development site, is updating the skin and software likely to break all the custom work I've done?
Ehren Posted July 9, 2017 Author Posted July 9, 2017 1 hour ago, steve bullman said: Cool. I'm finally going live with ips next weekend, wondering if I should do it with 4.2 You have seen my development site, is updating the skin and software likely to break all the custom work I've done? You'll need to reapply your theme modifications. The theme is coded from scratch and the code is significantly different, so it's not an automatic update like other minor upgrades. You'll also need to re-add the ipsfocus copyright unless you purchase copyright removal, in accordance with the Terms and Conditions. 1
JVCode Posted July 16, 2017 Posted July 16, 2017 Waiting for Elegant to be updated to 4.2 before making my purchase. Awesome styles, kudos to the designer(s) 2
JVCode Posted July 16, 2017 Posted July 16, 2017 Is Elegant going to be updated to work with 4.2 beta ? if so, what's the time frame for this? Regards,
Ehren Posted July 16, 2017 Author Posted July 16, 2017 11 hours ago, JVCode said: Is Elegant going to be updated to work with 4.2 beta ? if so, what's the time frame for this? Regards, Hello, On 26/06/2017 at 1:31 PM, Ehren said: Other 4.2 themes will be released over the coming weeks in a random order depending on when they're finished. On 08/07/2017 at 9:47 AM, Ehren said: ETA's for themes aren't provided since they can usually take longer than expected Elegant has not yet been started, so unfortunately I don't have an ETA, sorry!
Outsideheaven Posted July 17, 2017 Posted July 17, 2017 Hahaha I know I'm being annoying and I also know: On 6/25/2017 at 8:31 PM, Ehren said: Other 4.2 themes will be released over the coming weeks in a random order depending on when they're finished. But I'm just wondering if you started on Ortem yet.
Ehren Posted July 17, 2017 Author Posted July 17, 2017 2 hours ago, Outsideheaven said: Hahaha I know I'm being annoying and I also know: But I'm just wondering if you started on Ortem yet. Ortem has actually been available for 2 weeks now
steve bullman Posted July 18, 2017 Posted July 18, 2017 On 7/9/2017 at 8:23 AM, Ehren said: Dimension is now available. Ehren, how can I download this please? It doesn't look like its available in myorders on invision community
