Problem with the License Key
Go to solution Solved by Neejrow,
5 hours ago, victorgabr90 said:
There is a problem with your license key.
This message shows on the ACP shared with the administrators, what should we do?
Go to AdminCP>SYSTEM>SETTINGS>IPS LICENCE KEY
Check the license key status. Refresh it if needed. If that still has an error you may be using an invalid ips key.
Try contacting support via admincp>System>support but if that is not possible due to the lack of licence key you will need to Contact ips via their website.
