encontinuo Posted July 14, 2016 Posted July 14, 2016 Hi, I have seen there is required to update the themes if we have 4.1.13 version of ips. Last time we updated the theme, all was unconfigured and we had to apply all style changes again, so we are thinking a lot of updating theme or not. There is any way to update the theme without problems or changes? Thanks!
Ehren Posted July 14, 2016 Posted July 14, 2016 Hello, If you want to upgrade the theme manually, you can follow the instructions within the Difference Report
encontinuo Posted July 15, 2016 Author Posted July 15, 2016 Hi, With this method, can we update subway theme without loosing changes we have applied to the theme at the moment?. Thanks!
encontinuo Posted July 15, 2016 Author Posted July 15, 2016 Sorry, I think I understand more o less the process but I don´t know how to find the version of subway theme I have installed...
Ehren Posted July 16, 2016 Posted July 16, 2016 17 hours ago, encontinuo said: Hi, With this method, can we update subway theme without loosing changes we have applied to the theme at the moment?. Thanks! Yep - since you'll be manually upgrading your modified theme 14 hours ago, encontinuo said: Sorry, I think I understand more o less the process but I don´t know how to find the version of subway theme I have installed... You last downloaded the theme on May 27, which was the 4.1.12 version
encontinuo Posted July 19, 2016 Author Posted July 19, 2016 Thank you, it seems that now if we understanding it. You may do the same but in the subject? That is, make a manual update only files that have changed in the latest version regards!
encontinuo Posted July 19, 2016 Author Posted July 19, 2016 Our English is very bad Simply: It is possible to make a manual update of the theme, or we have to start over again, updating the latest version?
Ehren Posted July 19, 2016 Posted July 19, 2016 You must start with a fresh theme, unless you manually update your own theme. It is not possible for me to only send through the modified files.
