supercom32 Posted July 10, 2016 Posted July 10, 2016 Hey everyone, So I noted that when browsing the IPS Themes store, it appears that most of these allow you to have a "Color Scheme Editor" for users to play with. The older versions of the themes seem to indicate that you can turn these off via settings file. For the newer 4.1.x versions, how do you turn these off? The product descriptions don't mention that anymore except to say "This feature can be disabled easily if required.". How exactly do you do it now? Is it something simple, like a switch in the theme control panel? In addition, lets say I purchase the theme "Shift" for example, is there a way to set the default color scheme users see (Without giving them the option to change it, assuming I disable the menu option)? Is it possible to change the header background image to something else, other than the default pattern I see in the screenshots? If anyone with experience could answer these questions, it would make me feel much safer in terms of a purchase!
Solution Ehren Posted July 10, 2016 Solution Posted July 10, 2016 Hello, 1 hour ago, supercom32 said: Is it something simple, like a switch in the theme control panel? That's exactly what it is 1 hour ago, supercom32 said: is there a way to set the default color scheme users see (Without giving them the option to change it, assuming I disable the menu option)? Yep - there are already numerous tutorials in the customer area which teach you how to do this If you have any questions after purchasing, just post in the customer area and I'll most likely have a solution for you! Hope that helps!
rjkmelb Posted July 29, 2016 Posted July 29, 2016 I've purchased Swift and I am having a hard time working out how to force my preferred colour scheme onto users. Any assistance would be appreciated.
Ehren Posted July 30, 2016 Posted July 30, 2016 7 hours ago, rjkmelb said: I've purchased Swift and I am having a hard time working out how to force my preferred colour scheme onto users. Any assistance would be appreciated. Hello, A tutorial for that already exists
