Ehren Posted May 26, 2016 Posted May 26, 2016 All themes on both ipsfocus and the marketplace are now compatible with IPS.Suite 4.1.12, which was released yesterday. The updates also include numerous bug fixes and enhancements. Themes which have background pickers or color pickers will now instantly load the background image, which was occasionally delayed by a split second in earlier versions. If you have upgraded (or are planning on upgrading) to 4.1.12, the theme update is necessary in order to prevent any errors from occurring. That is all 1
EnigmaPatrick Posted May 26, 2016 Posted May 26, 2016 All themes are now compatible with IPS.Suite 4.1.12, which was released yesterday. The updates also include numerous bug fixes and enhancements. If you have upgraded (or are planning on upgrading) to 4.1.12, the theme update is necessary in order to prevent any errors from occurring. That is all Have you posted the updated version of https://invisionpower.com/files/file/7717-spectrum-ipsfocus/ to the market as I just downloaded it from there and I'm wondering if I've just downloaded the old version.
Ehren Posted May 26, 2016 Author Posted May 26, 2016 Have you posted the updated version of https://invisionpower.com/files/file/7717-spectrum-ipsfocus/ to the market as I just downloaded it from there and I'm wondering if I've just downloaded the old version. The files were just updated that second. Redownload them again since you likely got the old files 1
EnigmaPatrick Posted May 26, 2016 Posted May 26, 2016 The files were just updated that second. Redownload them again since you likely got the old files Just re-done it, thanks! 1
Empire Posted May 27, 2016 Posted May 27, 2016 New update to 4.1.12.1 is out. No problems regarding the theme. There is some CSS chnages 1
Ehren Posted May 29, 2016 Author Posted May 29, 2016 So does 4.1.12.1 require any IPSFocus theme updates? Nope - it's just a security update.
Azounstone Posted June 7, 2016 Posted June 7, 2016 On 29/05/2016 at 2:21 PM, Ehren said: Nope - it's just a security update. Does 4.1.12.2 need an update of the theme or is it okay to go ahead and update?
Empire Posted June 7, 2016 Posted June 7, 2016 35 minutes ago, Azounstone said: Does 4.1.12.2 need an update of the theme or is it okay to go ahead and update? It's safe, there are not updates regarding the theme since there was no HTML/CSS changes 1
