Wireless Theme
When might Wireless be updated to 4.X?
What are the chances that the new version will be all dark, instead of half dark/half light? The white section in 3.X clashes with the rest of the theme and isn't as easy on the eyes. Otherwise, it looks awesome.
I'm currently working on Ortem, followed by either Snapshot or Wireless.
The 4.x version of Wireless will likely be a combination of light and dark like the 3.x version. It'll be a free upgrade to existing 3.x subscribers, so I'm sure they would all appreciate a similar colour scheme for the 4.x version :)
  • 2 weeks later...
  • 4 weeks later...
You said that " free upgrade to existing 3.x customers".
I bought on June 2014, never received a update since that time, and now i discover that i have to buy again ?
